I am new to Shapr…I would like to design an plywood wall…Look up Parametric design furniture…
I can get the initial designs to work, just can’t figure out how to slice up the solid object into 1/2" or 3/4" parts to cut it from the plywood.
You can ADD a Plane, and move it to be in front of your object. On that plane, you can create very thin rectangles, then extrude them through your design to create individual components. You’ll then need to hide each body and export them one at a time.
Here is a short crude video of the concept. https://share.icloud.com/photos/0yDuved445hvp3Q77ufFDjLqg
