Please add SNAP ON/OFF TO ALIGN FACES, CENTERS AND CORNERS of two solids just by moving them closer
Faster/simpler alignment of solids/drawings/faces/centers
Simpler/faster alignment of two solids.
The same as snap to grid, or to angles (0/45/90/180), snap to align will automate the process to snap on alignment just by moving two solids closer. When activated, select one solid and move closer to another one will allow snap to alignment.
To long to do a simple thing as align to solids
I find alignment tool in SHAPR3D complicated to use to the point I stop using It. Precise but to much steps in the interface.
