Spacemouse settings resets after any normal mouse viewport click
Using a Spacemouse and have some settings tweaked (speed reduced + dominant mode enabled) the navigation via spacemouse is okay. But when I do any regular mouse click in the Shapr3D window, those settings are gone, are reseted to default maybe. So the navigation becomes very fast, dominant mode is off and other tweaked settings are set to default. And if I change any of the settings in Spacemouse window again, everything becomes as was before: dominant enabled, speed reduced and etc. So it seems any change in SpaceMouse window applies spacemouse all settings again. Click in Shapr3D resets settings to defaults.
What can I do to make settings stay tweaked without resetting?
Strange… I use the Spacemouse and (usb) mouse intensively interleaved. With all settings intact.
macOS 15.5
3DxWare 10 SpaceNavigator
3DxMacCore version 1.3.4.473 (473) Firmware 3.18
3DxWare version 10.8.4 (3716) [not up to date]
Are your setting global or set for only Shapr3D?
I find that among all CAD I use the implementation of Spacemouse in S3D is clearly the best.
