When I have more than one spline fairly close together to one another and try to adjustnone of them using its control points, how can I tell which control points belong to which spline? I find it very hard.
My suggestion would be to find a way to highlight the control points belonging to the spline being adjusted - perhaps by first tapping on the spline. Or in some other way.
It’s not a complete show stopper but it does make adjusting splines that are close together really tedious and hard.
Thank you.
