Hi, After the latest version I am getting different issues. I will describ one of them…
The Subtract tool. As I used to use this tool was to select an object that you want something else like a rod to be extracted from to make a hole. Probably there is an easier way and I will try that option in a bit. I have tried over and over and over again, just to subtract a rob to make a hold. This sound simple to me. This should be way easier than it is to the point of spending time to write this post. I am making a Fan Shroud for my Ender 3 Max with an intergraded Zesty Nimble mount that I got off Thingiverse. I want to put holes where the bolts are going to go to hold the Zesty bNimble to the Mount. So…
I start by creat a ROD.
2) I select the Subtract Tool.
3) I select the parts that I want have a hole in them (+)
4) I then select the ROD (-)
5) I tap done.
6) precess is finished
7) but no hole.
8) most of the time if I select one of the objects that were supposed to have a hole in it and select delete the hold appears.
This seems strange to me. Also, I seem to be getting duplicate/copy of the object I was trying to make a hole in. So maybe by selecting delete I am deleting a copy therefore revealing the version that actually has the hole in it. Also on the part that should have a hole in it I do see a circle like a 2D plain. I can select the 2D circle but I can’t delete said circle. I don’t know if there are 2D plains that I need to delete before this function will work. I tried deleting an objects under LAYERS that said PLain… but that did not fix the issue.
Also, I know there is the new Split Body Tool and I can not figure out how to use it. I don’t understand how or which plain to select. Do I have to create a construction plain before I can use the Split Body Tool.
I am almost positive it has to do with the duplication of the main(+) object that I need to delete and then part with the hole in it shows up. I hope this gets fixed soom. So frustrating but at least I figured it out.
YES, After the Subtract finishes if I Zoom in and then double tap in the circle show in the screen shot above then tap delete the hole appears. So defiantly the subtract tool is duplication the object.
