Svg export problem
If i export a sketch in .svg it is mirrored in other programs. Is that a bug?
Hey @Dennis_L,
What is your workflow when creating these sketches?
Hi, in this case i created a projection sketch from a solid body , i isolated all other sketches and then i exported it.
Thanks for bringing this up, seems like the issue happens if you project on the Front or Back plane. We’ll investigate it soon.
Thank you :slight_smile:
