pls add the Sweep2 feature or adjustable Loft function
I cant use shapr3d to make some basic shape which has curves,in other 3d app its a very common function.
Etc. I hope we can have the Cap function for making the surface into volume, because we might use the shapr3d while using rhino.
Laci_K
July 12, 2023, 6:55am
2
Have you tried the guided loft? I think it’s just what you are looking for.
yes, I’ve tried, it didn’t work.
Did you align the guides correctly with the upper and lower sketches?
Is this what you’re trying to do?
Thank you! Your comment really helped me to solve my problem, I checked the curves and find they were not align together.
