System crash when loading large file
What is the largest file I can load? And if I buy a new iPad I can get more memory will that help?
It depends on the iPad model you buy, and the complexity of the workspace. More memory helps, but depending on the model’s size, you might not be able to open it even after the upgrade. If you can share the design with our support team at https://support.shapr3d.com/hc/en-us/requests/new they can check how much memory it requires to open.
