I’m trying to re-create Model Mania 2002 (link below). Need to have a 7 degree taper on the sides and inside surface. Inside surface is shelled out. Can’t find a way to create a 7 degree taper on these surfaces.
Here’s a start.
Thank you very much! You did it so quickly!!! I have a lot to learn ![]()
Here’s a variation with 7° taper in both directions.
This is great! I need to change the way I think. I was trying to copy the method shown on the website done on the other program. This was very helpful. Thanks again!
Here’s my approach. The key to making the center angle rib that has a 4° draft is to use the Sweep tool. I’ll show that part again on the 2nd video.
Note that the only thing I did not do other than the various radii is provide a 4° draft on the tapered sides that step down 30mm shown in blue on the jpg pic.
Using the Sweep tool on the center rib.
Thank you! I will try this. I did a sweep before but now I can see where I made a mistake.
Here’s how to do the tapered stepped portion.
