About drawing
1.can’t change the font size and the Dimension line size
2.Can not add lines by myself
3.Unable to add thread line(Due to the reason of 2 or There is no threading option in the modeling module.)
4.Unable to add hidden outlines
5.Unable to add a broken-out section view
6.Difficulty in producing assembly drawings
7.It can only be assembled by moving, and precise assembly cannot be achieved
It is difficult to use Shapr 3D to complete drawings that require machining. Most of the time I need to import my files into other software.
I could not agree with you more, and don’t forget that if you add a new model to a (so called Assembly) that already has a drawing done with it you will need to redo the drawing if you want that new part to show up on that existing drawing. Which really Sucks.
