That is amazing and was everything modeled on Shapr3d. also how did you manage to get the dimensions for all the parts to reverse engineer them, great work.
Thank you for the kind words!
The goal from start was to do _everything_ in S3D, to learn and eventually overcome some limitations. This holds true except the decal on the air filter and the number plate. Here Affinity kept me sane and Vector Q kept the old plates intact. Usually I work in a plethora of CAD, shifting environment as soon as there is a uphill or to where the strengths is to be found; Fusion, FormZ, FreeCAD, Plasticity, Strata Design, Blender, Onshape. All this, but S3D is fastest and fun! (Though not always the most precise.)
The measurement is by thousands of photo with reference, lasers (combined), caliper, yardstick, strings. Countless hours in a sometimes very oily and nice environment. I wanted to create a true miniature where any small error would not in the end add up exponential and give countless misfits.
It all started with a missing radio — no S3D (later I did find an original.)
And then a water pump schematic and a missing antenna mount (later I also here did find an original), all in S3D, so why not do the all of her?
Started this Sisyphus work 2024 and I expected it to finish 2030, that still seem to be possible… The engine and et al is to be finalized, working my way inwards, with _all_ internal mech parts somewhat later.
(I also do some prints with working parts of rubber, carbon fiber, and metall to the 1:1)
Body WIP:
Frame:
My engine:
Original engine
1:1
Great work, I think that the Hudson was one of the most beautiful cars on the road back then. Keep up the good work.
Thank you
Outstanding work! Looks amazing.
Finally assembled the dry run for a friend.
This one is for the Hudson (informal) ‘museum.’ The only printout I will make is where all is original as from 1941.
(6v generator, coupe heater regulator, water dome, front bumper horns, and some springs here and there.)
The text for display worked out very well, floating.
I have two assemblies left to do where all is to be meticulously painted (as with the engine). One for frame display (as above) and one to go complete with the body.
The body will be complete with all lights and electric maneuvered hoods so I can showcase inside the acrylic box.
(More Hudson at https://HudsonSweden.com)
Amazing work! Can’t wait for the finished model!
Holy Moly, amazing!
Playing around with the new version 3 of Light Tracer.
Some small errors in the render (I probably have to replace some parts of the frame) and not all material is yet correct (I had to manually go through 2400 parts and group them to get a manageable approach at material changes in the glb file.)
Live at frame_pub
