三维数模的默认视角错了,怎么重新定义视角
上传:视角错误.png…
默认视角是错的,怎么重新定义默认视角、主视角等各个视角
另外XYZ的轴线是否可以调整,旋转的时候不跟手
Ніхто не розуміє що ви пишете. Якщо звернете увагу то тут всі спілкуються суто англійською мовою.
嗨,
我从英语翻译了这个,因为我不懂普通话/中文。
那么,你的观点是错误的是什么意思呢? 如果您想要更多正交或透视视图,您可以在右上角的外观下进行调整。 目前,您无法修复相对于视图的xyz轴,老实说,我根本看不到它的视图。
如果以后你用英语写作,那就太好了。
This is a dead end. Trying to translate to or from Chinese using a translator is the worst idea ever — meaning gets lost way too easily.
I know. But there must be a reason why Frank wrote in Chinese - so he probably can’t write / read English, and the only way to answer him is by a translator.
Так, я теж помітив, що це відкритий міжнародний форум. Я можу спілкуватися через перекладач.
That’s great, so please respect others and use English for communication. I’ll stick to English as well and won’t write in Ukrainian. :slight_smile:
Uploading: 问题1.png…
Uploading: 问题2.png…
Thank you for your kindness. Indeed, I’m still learning English, and I’ll use English to ask questions like everyone else on the forum. I’ve also rephrased my questions and hope to receive your reply. Thank you!
Got it! Thanks for the heads-up!
