Trailing zeros in drawings / dimension settings
Hi!
I’m having trouble to get my dimensioning in drawings right.
In the construction field I`m in, dimensions are shown this way;
If you have for example a wall that is 240cm = 2,40m, you write 2,40. If there’s only 40cm, you write 40. The “boarder” so to speak is 100cm.
Therefore it is important that a 4,00m (or centimeter in this case for 3d printing) long wall is written 4,00 and not 4 - otherwise it could be misinterpreted as 4cm. In this example chances for this to happen is slim, but there’s strict rules and therefore I want to have two trailing zeros in all dimensions. I can’t get the setting right tho. Could anyone please give me a hint what to do? I modeled a 1:100 model working in centimeters.
In the screenshot, I’d like it to show 12,40 , 4,00 , 8,00
I’m using an eductional license with an iPad on Software 26.32.
Any help is much appreciated!
Cheers
Luca
Tried to figure something out for you, though it seems that the 4 stays a 4.
You can try and add suffixes individually (like 4 , 00 ) but that sounds rather unattractive.
To do that doubleclick the numbers; perhaps you can do some stuff with the below 1meter values and some Prefix Text as well.
Thank you very much for helping! I appreciate it. It’s not perfekt but works okay!
