Translate function with 2D objects
I’ve never contacted support before, because your product has always been fairly intuitive. It did cause problems now and then, but I could usually sort them out by trial and error. Today, though, I’m beyond frustrated, guys. I spent a full hour and a half of my life trying to move selected 2D objects from a specific point to a point on another 2D object. And you know what? I couldn’t do it.
Just think about it: I’ve been using your product for several years, and today I couldn’t do an operation that used to take me 10 seconds. It’s honestly awful. I wasted my time and didn’t finish my work, all because you broke a function that never used to take any effort.
I’d like to ask your developers for a detailed answer with clear instructions on how to do this, because after the latest update I simply can’t figure out how the Translate function works on 2D objects.
What function are you talking about?
Translate function
OK…
How did you use Translate in Sketch without bodies?
In Sketch (2D) without bodies, i use Constraint settings
I mentioned this problem a few days ago.
It seems the shapr3d team is ignoring this problem.
Someone raised this question before the last update.
But as usual, I didn’t get a response.
The team seems to have been focusing on fancy new features all along.
For a professional modeling software, it should focus on stability.
Whether it’s workflow or tools
Even having a large group of long-term supporters of users is even more so
I hope they focus more on the development of new modeling tool function and the improvement of the functions.
This is the foundation of this software, not fancy AI and 3D printing or compatibility with new devices.
In some cases, 2D CAD is obtained from the client or from the company’s internal systems and then converted to 3D.
Not all software users are engineering personnel from the design side.
This type of requirement also applies to collaborative work between cad/cam or colleagues.
Sketch translation will be of great help at such a time.
Hello,
I am interested in this discussion, can you show me or explain a concrete example of 2D sketch translation.
I admit I don’t understand exactly where the problem is.
old version
new version
Draw a line, make Construction (or not) and change the distance (video1). Add Constraints if you want.(video2)
This practice needs to enter sketch again to be completed.
If it is allowed to directly translate an existing 2d line segment to a point
Fewer operation steps are required.
With translation, it can even be achieved in one step.
You way: sketch>constraint>set parameter>done *only useful for 2D space
My way: Translation > Select point>done * 3D space is useful
Not obliged…
But I never knew the Translate tool for Sketch.
You will have to wait for an Expert to pass by here. :slightly_smiling_face:
"This is a very real problem and you are absolutely right: in the latest versions of Shapr3D (deployed in October 2026 with the arrival of the new parametric history and “Parameter Cards”), the Translate tool of the Transform menu no longer allows you to select raw sketch elements.
This is a change in the logic of the application that disturbs many users. From now on, the Transform > Translate tool is strictly reserved for volumes (Bodies), faces and 3D edges."
Personally,I always try to prepare my work well in Sketch mode (Dimensions, Constraints, etc…) before switching to 3D mode.
Just 2 clicks to position my elements (no more than with the Translate tool)
and you can modify in 3D mode
(I have a keyboard shortcut to hide/display the dimensions)
IMHO, it’s cleaner … And without leaving 3D mode
This is what I talking about it
in this situation use translate function with 2D objects and that’s also the reason I’m complaining. They no longer have the freedom of the previous tools, which has affected my workflow.I use this function while working with Siemens NX.
“…the Translate tool of the Transform menu no longer allows you to select raw sketch elements.”
Here my process: work on the sketch before (video1)
or like that…
video 1 can it work on different plane?
if it can’t
I think the shapr3d team need to bring it back
they can’t add new function and cancel tool’s function in the same time
This means there are no other transitional measures to reduce users’ friction Right?
yes, of course…
let’s see the video >
The point I want to express seems to be far from you.
This topic has always been talking about the paragraph you mentioned.
:downwards_button::downwards_button::downwards_button::downwards_button::downwards_button::downwards_button:
Many users hope to using translation sketch.
OK!
Wait for Team or Experts answer.
Right, that’s what I am talking about it.
Sorry for long answer, and i am here again. Previous messages show how u use constrain function with simple objects. But, if u need work with more complicated 2D object which includes straight lines, several splines and circles. In this case, how you can transform object from point to point of another object. Haha, I can’t upload a video because I am new user =))))
I am going crazy with that. Ok, my point with your take is that I couldn’t use the constrain tool like you in 3 different ways, like you do with choosing 2 different objects and set 0 mm length between it, and couldn’t use method where youn choose one object and move it by hold a point (in this case, spline points hold position and don’t move with all object, one more with translate toll - I choose my 2D object to move it to another, but when I am trying to select another 2D object first one is deselecting and so on in a circle. So, maybe somebody help me with that, honestly it’s not good, I couldn’t understand that logic. Example in photo below: #1 - main point of my object with spline lines, #2 - corner point of object where I want to connect
