Why can’t i trim this one line where it intersects with the body. I feel like I have to learn shaper3d all over again cause it’s changed so much. I used to be able to trim any piece of it intersects with another line. I want to get keep the bottom smaller line but not the longer line with the red arrow I drew. Can anyone help?
Your vertical line might not be on the same plane as the horizontal edge/line.
You can project the horizontal line, the line you want to use to trim to your vertical line so they intersect on the same plane and you will be able to cut it.
Sometimes I had issue where it was on the same plane and couldn’t trim. I scaled, increased the length to kinda like nudge the intersect then I was able to trim I think thats was a bug.
