Hey there. I’ve got two channels coming together. Theyre going to be milled after setting them up in fusion. How do I delete the line at the intersection in this image? Thanks in advance. Jonny
Assuming it’s a sketch, select any of the line sketches and the Trim tool will show up. Use it remove that area.
Uhhhhhhhh…that was ridiculously easy. So cool. Thanks a ton.
