Two Finger Tap to Undo
I use many applications that support the ‘two-finger tap’ gesture for the Undo command. It is a wonderful habit that makes for quick and easy workflow. I would like to see Shapr3D support this gesture. I look forward to the smooth, consistent iPad Pro workflow this gesture provides.
Hi, we had the two/three fingers tap gesture for undo/redo until the release of the iPad OS. We then updated the gestures to the iPad OS three fingers left/right swipe for undo/redo.
Yes! No more “undo” button! Thank you very much! :japanese_ogre:
Could it be possible to toggle between these in settings? I prefer the two/three finger tap for undo/redo but I do see why you would want to have the same as the ipados native way of doing it :slight_smile:
@Victor_Shapr3D Is this a possibility in the future? I prefer tapping too.
