.unexpected revolve change
I wanted to profile the bottom of this bottle as I originally made it flat. I went back to the original sketch and then found that the diameter of the main object was wider than the sketch. How can that be?
After you did the Revolve, did you use the Shell tool?
If so, did you use a negative number for the shell?
