Peter,
Another smaller UI issue is how an item (body,sketch, plane…etc) when deleted during the design is tracked in the item list.
When I am creating a design I will regularly change my mind and delete what I just created. The annotation is still showing in the items list and was not removed. It canno longer be highlighted and must be “slid” to trash.
I have included a screenshot that hopefully explains. I have a active body highlighted and the deleted item being slid to delete.
Could you record a short video of when this happens and perhaps share the exported .shapr file? The items list should be updated properly when you delete something and it does so for me an all platforms.
Here is the.shapr file
Neil
UI Delete Issue.shapr (833 KB)
Thanks, we could reproduce it. It seems to be only happening for active sketch planes, other items can be deleted properly. We will fix it soon, but until then a workaround can be deleting the sketch plane without activating it, directly from the items menu using the slide/right click menu options there.
