In red, crenellation !
Vector to STL or OBJ - Adobe Stager Render.
What could be the solution to avoid crenellation?
Hello,
Thank for your answer. I work on Ipad Pro.
Test for export : HQ STL ( resolution maximum) and OBJ | compatible export for Stager. The 3MF isn’t compatible for the Adobe Stager render.
► I don’t have this effect in native mode.
SCREEN COPY IN NATIVE MODE
3MF High Resolution on KEYSHOT
After several attempts, it seems that the crenellations are only present with this piece. I have tried other geometrical shapes that combine the booleans and I don’t have any defects.
I’ll redo this part and see if it’s not a random error caused by the booleans.
The last part has no defect and it was built with the same functions.
I’ll redraw and republish a little later.
