Weird constraint sketch behavior / bug
Hi Shapr 3D Team
I am very impressed by the software and I wanted to create some replacement caps for my cloth dryer that are getting broken.
The diameter of the tubing is 13.1 millimeter so I am trying to create an L shape with a 6.55 millimeter in the short leg.
While trying to create and adjust this L shape, I found 1 bug and 1 puzzling feature:
I don’t know if the above is a bug or a feature, but it is extremely annoying, as that can throw off a big sketch.
Using Shapr3D 3.1.3 on iOS 11.4 beta 2 iPad Pro 10.1”
Any comment would be much appreciated.
Our sketch engine is being replaced. It should be released in 3-4 weeks.
Does that mean you’re switching away from Parasolid, the same engine that powers SolidWorks, Siemens NX, Solid Edge and many more run on? That was a recent upgrade wasn’t it?
No. That’s the geometric engine. Sketch engine is just the part that is used for the constraints. Parasolid rocks. :slight_smile:
Wow, thanks for such a quick reply! Looking forward to the next revision.
