i thought the speed and calculations of the file are affected by ram, and my ram is 32gb ddr5 so it should be very fast and i dont ahve any other background apps open. My file is fairly simple so im confused on why it’s so laggy.
Do you have some complex circuit board inside? In general what you created doesn’t look complex and should not give you the lag even on on low end machine.
If you post your file someone can confirm it for you, if not looks like a support ticket with Shapr.
it’s only with this project ? or for all ?
