Why won't my sketch extrude?
I am new to Shapr3D and am needing some help. I keep getting this error while trying to extrude the sketch I made. Any ideas on how I can fix this?
You can divide your drawing into several parts with lines. Then try to extrude the parts. Where it doesn’t work, the error will be in that part.
Thank you so much JST! I have located the error and got it fixed. Thanks you again!
