Windows bug
There is a critical vulnerability in the Windows system: scaling a model causes the 3D object to disappear, which prevents real-time creation. Please fix this vulnerability.
Hi @liguizhuo
We’ll open a Support ticket to look into this in more detail. Please check your inbox and provide any additional information that could help us investigate.
Thank you for reporting this.
Every modification of a 3D-object makes this object to disappear. it reappears after “enter/done”. If, for example, i click on an edge, the edge is highlighted, as before, but when i drag the arrow to create a fillet the object dissapear, and only the highlighted edge is visible. It is verry anoying, and makes work verry challenging.
Yes, this is extremely frustrating and impossible to continue.
Hello, @Redhumana Does the 3D object disappear every time you scale it, or does it happen only with certain model sizes?
Hi @liguizhuo
A quick update on this: this is a known issue affecting some Windows devices with NVIDIA GPUs based on the Pascal architecture.
On affected devices, 3D objects can temporarily disappear from the tool Preview while using operations such as Scale, Fillet, Offset Face, Extrude, and others.
A fix is already on its way and is currently planned for an update early next week.
In the meantime, switching Shapr3D to DirectX 11 under Settings → Graphics → Backend → DirectX 11 remains the recommended workaround.
We’ll update the thread once the fix is publicly available.
