Environment
- Device: Microsoft Surface Pro 9 2038
- OS: Windows 11 26H2
- Input: Renaisser Raphael Pen + Touch
- Shapr3D version: 26.211.12479.0 #99e77d0c
- Plan: evaluating before subscribing
- Bug: tool panel follows the pen cursor and blocks input
Steps to reproduce
- Open a project with at least two bodies.
- Select a tool with the pen, for example Subtract.
- Move the pen across the screen.
Actual result: the tool panel follows the pen cursor everywhere on screen, so I cannot tap anything else (bodies, other controls).
Expected result: the panel stays where it is so I can select geometry and use other controls with the pen.
Workaround: holding the pen in place and dragging the panel away with a finger frees it briefly, but the panel starts following the pen again immediately afterwards.
Frequency: every time, with several tools (Subtract is one example).
I can provide a screen recording on request.
- Feature request: configurable pan/orbit for touch and pen on Windows
I would like:
- Single-finger drag / regular drag = pan
- Two-finger drag / Alt + drag / right-click drag = orbit
I could not find an option in the Windows version that allows this mapping. If one exists, please point me to it; otherwise please consider adding custom navigation mapping for touch and pen.
- Question
Is pen + touch on Windows (Surface devices) an actively supported configuration, and are fixes for the above likely? I would like to know before committing to a subscription.
Thank you.
