Wire frame or reduced quality
Creating drawings with thousands of items causes crashes and something simple like moving objects takes time for ipad pro to process and becomes very laggy.
By being able to choose a wire frame mode or low quality mode, this might allow for faster work, less memory crashes
What can’t you achieve without this feature? highly complex models withn thousands of items can be edited quickly without crashing
*Is this a workflow blocker for you? Is this why you can’t use Shapr3D for work? Is this slowing you down?
Yes, constant app closing and restarting and is time consuming
Absolutely signing on this topic. Same problem here.
