Hugo pointed out it requires Shapr3d Cloud, so the answer for now is basically can’t do it locally unless they add the feature. I just pointed you might need to save it locally, I was just curious whats the benefit other than it removes a step.
Example, Makerworld and Fusion has Parametric Abilities.
it was mentioned above, but it took me a little to understand so i figured i would explain what i did just in case it helps someone else:
I colored a model and tried to send it straight to bambu slicer, but it kept importing with a config error file and all one color. The reason it didn’t work for me is because my model had two colors on one body. I redid the design and kept the bodies separate and it imported correctly and allowed me to map my colors.
It would be nice if the bambu help file said something about each body can only have one color, that would have saved me alot of time. I also forgot that obj saves color info so using that instead would have saved me some time too. I usually don’t color models but i was doing a promo item for a friend and didn’t want to use the bambu tool
