26.220 – New modeling tools, expanded import support, and workflow improvements
This release introduces new modeling tools, including Primitives, Bridge Curve, and Intersection Curve, alongside expanded import capabilities and improvements across sketching, Design History, and 2D Drawings. Plus, full modeling is now available on iPhone Duo, and the new Recently Deleted feature makes it easier to recover projects.
Shapr3D on iPhone Duo
Take your modeling workflow on the go with the full Shapr3D modeling experience on iPhone Duo.
  • New: Full modeling on iPhone Duo – Create and edit 3D designs directly on iPhone Duo, with support for sketching and modeling using Apple Pencil.
Modeling and sketching improvements
Create and refine geometry with more control and faster sketching workflows.
  • New: Curvature combs – Analyze curvature along sketch curves and model edges, with adjustable display density.
  • New: Horizontal/vertical points constraint – Align sketch points horizontally or vertically.
  • New: Find Open Ends – Quickly identify open ends in a selected sketch to troubleshoot why sketch profiles aren’t closing.
  • Improved: Sketch Trim – Trim multiple sketch segments in one continuous action by dragging across them.
  • Improved: Sketch Extend – Extend sketch geometry using curve extensions or world axes as references.
  • Improved: Shell – Choose between Sharp and Round corners when creating uniform-thickness shells.
  • Improved: Align – Align geometry directly to world planes and axes.
  • Improved: Slot – Adjust the slot radius based on the cursor’s distance from the arc center.
  • Improved: Thread – Create threads optimized for 3D printing with 90° thread profiles, adjustable clearance, and automatic runout chamfers. Plus, work more reliably with thin-walled geometry.
New modeling tools
Create basic 3D shapes and connect geometry with new modeling tools.
  • New: Primitives menu – Access tools for creating basic 3D shapes in one place.
    • New: Box – Create rectangular 3D solids.
    • New: Sphere – Create spherical 3D solids.
    • New: Cylinder – Create cylindrical 3D solids.
    • New: Cone – Create conical 3D solids.
  • New: Bridge Curve – Create curves connecting two edge ends and adjust their shape using on-canvas controls.
  • New: Intersection Curve – Generate curves where two sets of geometry intersect.
Dashboard and project management
Recover deleted projects and manage your workspace more easily.
  • New: Recently Deleted – Restore projects within 30 days of deletion from the Recently Deleted tab in the Dashboard, including personal and Teamspace projects.
  • Improved: Settings – Find options more easily with reorganized Input and User Interface sections in Settings on Apple platforms.
Import improvements
Bring more file formats into Shapr3D and work with imported geometry more flexibly.
  • New: SketchUp import – Import SKP files as meshes, with the option to convert compatible geometry into editable solids.
  • New: OBJ import – Import OBJ files with their associated colors, materials, and textures.
  • New: STL and 3MF to editable solids – Convert compatible mesh geometry into editable solids during import, with adjustable conversion time limits.
  • Improved: SVG import – Import additional SVG elements, including symbols, text, and markers.
  • Improved: PDF import – Choose from different quality presets when importing PDFs to better capture fine lines and small details.
Design History improvements
Organize and navigate complex modeling workflows with the updated Design History panel.
  • New: History groups – Create, rename, and organize modeling steps into groups in a tree structure.
  • Improved: Breakpoints – Insert and reposition breakpoints with new context menu actions.
  • Improved: History navigation – Identify steps with errors and navigate modeling history more easily.
Items and workspace improvements
Find, organize, and manage design elements more efficiently.
  • New: Items search – Search and filter bodies, sketches, curves, and other elements directly in the Items panel.
  • New: Interactive quick measurements – Hover or long-tap on quick measurements to preview their annotations or pin them directly without entering Measure.
  • Improved: Keyboard navigation – Navigate items with arrow keys and rename focused items using keyboard shortcuts.
  • Improved: Saved views – Rename saved views to make frequently used model perspectives easier to identify.
Visualization and Screenshot improvements
Capture and present designs with more control over materials and rendering.
  • Improved: Generate Render – Access Generative Render directly from the Screenshot dialog.
  • Improved: Normal Intensity – Adjust Normal Intensity independently from Roughness for more control over surface detail.
  • Improved: Decals – Rotate and scale decals using on-canvas handles.
  • Fixed: PBR export – Resolved normal map seams and other issues affecting exported materials.
2D Drawings improvements
Create and edit technical drawings with greater flexibility.
  • Improved: Drawing creation – Create drawings using the updated tool card interface, with drawing standard and orientation settings.
  • Improved: Drawing views – Add or remove bodies from existing drawing views without recreating them.
  • Improved: Dimension precision – Set custom precision for individual linear and angular dimensions.
  • Improved: Note leaders – Select, delete, reposition, and reattach note leaders.
Windows compatibility
  • Updated: Minimum graphics requirements – Shapr3D 26.220 requires DirectX 12 on Windows. DirectX 11 is no longer supported.
  • Improved: Dashboard menu bar – Access File and Help menus directly from the Windows Dashboard.
Try out the new tools and improvements, and let us know what you think in the comments!
This bug related to the JSON format has existed for many versions and can be found everywhere. It is hoped that it will be given attention and fixed.thanks!
Love the history grouping. I’ve been waiting for this ever since Shapr3D went to history based parametric modeling.
it’s just me or this thread is very slow?
No! We can’t have that:
Thank you for the Search Items/Steps! I would love to have the string (^)‘grep:’ activate REGEX/GREP in the text field.
I was talking about scrolling in this topic.
On my Mac Studio, the videos are laguing
I love the history folders! It might seem like a minor thing but it helps so much in navigating and finding steps, especially in projects where it is several pages long.
2D Drawings: Adding a body however make it relative / in place to existing bodies already on sheet. :slight_smile:
Wow things have accelerated recently! Some really good stuff in this!
I can now just make a sphere without having to sketch it? Witchcraft! :wink:
same as you
Fantastic new editions and many thanks for the thread tool fix. Shapr is stepping up. :clap:
I think that the latest updates are great and the Shapr3D team are doing a really good job. But I would like to see a lot more improvements to the drawing side of Shapr3D like being able to:
more options to dimensions like (arrows in or out, being able to change text size, dim. text justification location)
being able to move section views anywhere on the drawing (not locked to the projected view it was created from)
being able to move the text “Section A-A” to different locations instead of being locked.
being able to change the ISO view to being shaded
Another improvement to Shapr3D would be adding a Assembly Mode.
Thank you
And not to forget: full Apple Pencil Pro support still missing. Waiting since years. No double tap supported, no “squeeze menu” support. E.G. double tap to switch between construction and regular mode in 2D sketches. But so far, great improvements. IMO the development teams focuses to much on visualisation effects which aren’t really important for me. Of course just my opinion…
I’ve tested the updated Thread tool in a practical 3D printing application.
The 3D-printed M6 bolts fit standard metal nuts perfectly and screw in smoothly. I’m currently using them to assemble a physical prototype of one of my projects.
The updated Thread tool works very well. Thank you for this improvement!
Same here. This thread is extremely slow on all my devices: iPad, iPhone, and MacBook (M2). Sometimes I have to wait a minute or two for the page to load before I can post a comment.
Same here; it should be a Safari issue. I switched to Chrome and it worked fine.
I know why this page is slow.
The “videos” in the original post are gifs, but recorded in a full screen resolution. Not all browsers and machines will handle this very well.
The curvature comb one is 22MB! A bit much for embedding. :sweat_smile:
Thanks for this report. Will be fixed with the next release.
Great improvements. Thank you
