5.380 - Granular 2D Drawings properties and improved Visualization performance
We’ve been adding more granular control over a few 2D Drawings properties:
  • Improved: You can now change projection type independently of the sheet standard.
  • Improved: You can now easily change between different decimal separators.
  • Improved: We added more options for scale values, allowing you to choose a scale that best suits your preference.
We also have been working hard to enhance your Visualization experience:
  • Improved: Visualization just got a performance uplift. Now you can enjoy a much smoother and faster rendering of your models. Check out the comparison below.
    Before:
    before
    After:
    after
Try out these improvements and let us know what you think.
Jeriz I just wanted to let you know that the latest improvement to the Visualization Performance is amazing. I had a very large assembly That I imported into Shapr3D quite some tome ago and i kind of gave up on trying to do the rendering visualization on my Ipad pro because it was such a large assembly with a lot of parts that it would not render correctly and to rotate the assembly was pretty bad. But since the update of 5.380 I thought I would give a try on my ipad again and it works great rendering and rotating is seamless. I did try to “share” but it timed out on me and would not create the link but I think that has more to do with the app viewer it is created thru because of the size of the assembly.
Thanks to the Shapr3D team keep up the good improvements.
The difference is amazing…
Still a little jerky but considering this is 40,000 individual bodies running on an M1 Mac with just 8GB RAM I think this is quite impressive.
