5.500 - Update project names quickly
This release focused on remaining minor enhancements and bug fixes to give you a smoother design workflow.
Regular release updates
  • Improved (iPadOS and macOS): Manage your project names faster by renaming your projects directly from the modeling space.
    5.550-ipad
  • Fixed (iPadOS): An issue with some complex designs no longer opening on iPads due to higher memory consumption has been resolved.
  • Various bug fixes and improvements.
Beta release updates:
  • New: Create smooth transitions between faces with the new ability to define G1/G2 continuity at the beginning and end of Loft operations.
Let us know what you think in the comments down below. :arrow_down:
Great! Shapr3d just keeps getting better and better!
Thank you-
Many thanks for these great improvements.
Curious! Why did version number jump from 5.492 to 5.500?
We use a major version.minor version schema, where the end of the minor version is 0 for the initial release, and bumped whenever we release a patch or fix which is still built on the same release. So after 490 there comes 500, the reason for 491, 492 and 493 is because we patched things.
