5.930 - Sketching upgrade and Dashboard updates
Sketch faster and manage your projects with more control. This release brings major performance improvements to sketching and new options for Dashboard sharing and storage.
Sketching performance upgrades:
  • Improved: Sketch plane selection is now significantly faster, especially in large sketches with repeated or patterned curves.
  • Improved: Overlapping selection popovers now open instantly, even when multiple curves are stacked.
  • Improved: Activating temporary sketch planes is up to 19× faster, reducing delays in workflows like section-based sketching.
  • Improved: Drawing and snapping on temporary planes is now much more responsive in dense or imported workspaces.
  • Improved: Moving large groups of sketches is up to 4× faster.
  • Improved: Importing large DWG drawings with thousands of curves is up to 25× faster.
  • Improved: Opening workspaces with a large number of sketches is now up to 10× faster, depending on geometry complexity.
Dashboard updates:
  • New: Now you can turn storage optimization on or off in Settings for each device, controlling whether inactive projects are automatically removed from your device after 30 days while remaining stored in the cloud.
  • Improved: The Conflict Resolution dialog now shows who last edited the design.
  • Improved: Now you can open the Share dialog directly from a project’s context menu in the Dashboard by right-clicking or secondary clicking the project.
  • Improved: When switching teams in the team switcher, the subscription type is now shown next to each team name.
  • Fixed: Opening a project link in your browser and selecting “Open in Shapr3D” no longer shows an access error when another team is active. Shapr3D now switches to the correct team automatically if the project is shared with you.
Try these updates and share your thoughts in the comments below. :down_arrow:
What exactly are “temporary sketch planes”? Never heard of it before. Or are these just the planes that one creates, then sketches and then deletes?
this is the case where you’re sketching on the face of a body, etc. instead of a specific plane created for the sketch
I still find the translucent planes difficult to see at times, to be honest. It’s one thing when they’re highlighted and they turn blue, but in their normal, whitish translucent state they can be difficult to see. This is size dependent of course, but then I never know what size plane I’m going to get when I click “add plane” to a face.
Maybe you guys could consider adding some kind of dashed line around the perimeter of planes to make them easier to see when they’re not highlighted?
I’m not exactly sure why sketches disappeared for me permanently when let’s say extruded, but after updating my Windows it shows as a “turned off” sketch again. What am I missing here?
I’m pretty sure I have to figure out History’s ways a bit. Would it be possible to amalgamate History with Items window and make Items(Bodies/Sketches etc.) separately viewable(enabled) and editable through History?
