5.960 - AI Capture in Visualization, Section View Interference Checks, and in-app access management
Although the GenAI render in Shapr is far more precise than other GenAI image generators I’ve been using, I’m still experiencing some cases where the visualised geometry is deformed and different from the original geometry (e.g., an original bottle with a handle, showing without a handle in GenAI). Also, quite often, the view of the geometry is not the one I initially set up.
You can prompt that.
The GenAI is strugling a little bit with rendering correctly text and other graphic elements engraved on a geometry.
I complemented the geometry with a prompt, but the geometry deformations and the absence of elements remained.
More info here:
https://support.shapr3d.com/hc/en-us/articles/20520096011164-Shapr3D-AI-User-Guide-and-Data-Use-Overview?utm_source=app#ai-chatbot-guide
I am note getting the option for Generative Render on my version 5.970.0. Is it not available currently or is there a setting to enable it?
