Add radius dimensions to the 2D sprite, as shown in the AutoCAD example.
Could you please clarify your question? Do you want to recreate this drawing in Shapr3D, or create a part with the same parameters?
The piece is already finished, I just can’t add the measurements during the curve. As shown in the photo.
Like this?
Yes!
How did you do it?
Here’s the drawing; I was only able to get the measurements as shown in the photo, and I need to place them on the inner and outer curves of the cut piece.
copo Complet 19cl.pdf (130.2 KB)
I just created a drawing and added the dimensions (as shown in the video).
The internal dimensions are different because I didn’t even try to replicate them.
This doesn’t really help to understand what the problem is. It would be easier if you shared the model itself.
copo 19cl.shapr (810.2 KB)
Thanks for help
