Allow you to make conical compression springs, flat coils and other conical revolve components.
To be able to adjust height, diameter and rotation degrees of a revolve in real time
Have no clue if is even possible to make any of the above with this addition. Possibly with out lots of planes and sketches.
Is definitely limiting my design progress. Think it will be useful for others too
