Adding text?
Am I still correct in assuming there is not a way to add text?
I noticed questions on this topic dating back to the year 2016. So, here we are 4 years later, and we are still being asked to work around the fact that there is not a way to add text?
I just started using the app and this is a huge limitation. There is no way I can feel good about paying for an advanced version of the app when i can not do all the things i need to with it.
You are correct. I only found this out after subscribing for a year and it’s really troubling. You can either trace an image of the text you want, or someone on the form has a shapr file with text already drawn you can use. But supporting this feature is long over due.
Hi Aly, the text feature comes tops on our road, at the moment there is no ETA for when it will be deployed.
Here’s where to download the alphabets workspace created by a user that can be imported into your design, and then you can project any letter to your design using the Project tool:
