Any tips on modelling wood?
Hey Everyone, I’m wondering if anyone has modelled wooden surfaces, such as planks? It’s something I can do in Blender, but I’d like to do all my modelling inside Shapr3d if possible. Any tips, tricks, or workflows are much appreciated.
Thanks in advance.
Mark
:slight_smile:
I did a little bit, but am hoping to do more. Im looking to work with a specific plank size and build up pieces from there. I think shapr is good for that.
I have a yearning for wood, getting a little tired of plastic.
Im curious, what’s the part in the background for?
I usually recommend doing exactly what you would do when working with real wood.
For example, if you’re planning to build a table out of boards and beams, start by modeling a board and a beam using standard dimensions (the sizes you’ll actually be able to buy).
Then make copies of those boards and beams and perform the same operations you would in real life.
For instance, let’s say you need to cut a piece off a board at a 60-degree angle. In real life, you’d first mark the cut with a pencil. In Shapr3D, you’d create a sketch on the board. Then, instead of cutting it with a saw, you’d use an Extrude Cut.
And so on. :slight_smile:
Once you have all the parts, just use the Align tool to assemble everything together.
Not sure. Some split body for some reason. Im not very tidy in my work flows. :blush:
Leverage parametric design habits. If you are looking for texturing surfaces to simulate wood more closely, you will not get the same results as Blender. However you can flesh design out in Shapr easier and export to Blender for that.
