Camera lens
I have been testing Shapr over the last couple of weeks before embarking on some real projects.
Pretty happy with this with the exception of the graphics that I have applied in Adobe Dimension…Just can’t get enough resolution for real projects
50
Continuing the discussion from Camera lens:
This is stunning. I’m assuming it has full detail? Can you show a cut through also? Very impressed with the rendering.
IMG_0007 PNG
Hi @MM46
can you please explain how you render this way?
Hi Tayfun1907
Models created in shapr and then imported to Keyshot, materials and lighting applied and rendered.
M
thank you :slight_smile: @MM46
how did you make the curved lenses?
Hi MarMar
Draw half the lens profile, select the closed shape and simply use the revolve tool to revlove around the main centre line.
M
