My nerves… guys i need help, iam so frustrated… no matter what i do, when i put on a new construction plane, it keeps sketching beyond it. What do i have to do to sketch directly on my plane? I even tried to select it so its blue (indicates as selected) and them i pressed “sketch” but it still did draw behind this plane.
Did you double tap the construction plane with your finger? Pencil and finger are different.
No, will try
You can also tap on the plane with the pencil and select Sketch from the tools to the left. It does the same thing.
Hi there, I’m having this problem but I’m on a macbook pro - so I tried double clicking on the trackpad - or selecting first the plane and then the sketching - I accidentally got it to work once but I can’t figure out the combination of keys/clicks I used to get it - any help is appreciated - this works fine on my ipad.
Hi so it seems I’ve found the answer - if I hover my cursor over the plane and at the same time press the space bar then that plane is selected for drawing.
Happy days.
