Centering
Centering
Hello,
I’ve positioned four circles that I’d like to center perfectly in relation to a large square with rounded corners.
I can’t figure out how to do this automatically.
I’ve encountered this problem quite a few times before.
Hello, thank you for your feedback; I learned a lot from watching your video.
However, it doesn’t work as well if the object isn’t centered.
I would like to know if there’s a function that allows you to select a shape, group it, and then center it all relative to another shape or another set of lines. For example, centering horizontally and/or vertically. Like how it works in other software.
Thank’s in advanced
It works the same way — you just need to add different constraints. I showed it in the center because it’s always the more convenient place.
No. But you can add appropriate constraints that make the figure act like a group, and then you can center it using even more constraints.
Thank you, thank you.
Yes, it’s exactly the same thing, and indeed, I need to think differently when I’m drawing and using constraints a lot.
A French manual for Shapr3D is really needed, and that’s a real problem.
Thanks again for your help; it’s been very helpful.
you can go to menu Help > Shapr3D Help
In your browser, you choose : Translate in french
