Interesting what he has to say about exporting STL vs Step.
It looks like “smart infill” is going to be a thing in the near future. I’m hopeful it will encompass holes.
Some practical notes from printing a lot of exported parts:
- If your slicer reads STEP (PrusaSlicer 2.6+, Bambu Studio and OrcaSlicer all do), send it STEP. The slicer then meshes the true curves itself, so you skip the export-resolution guesswork entirely.
- If you have to use STL, export at the highest resolution. Low-resolution STLs turn holes into polygons, and a polygon’s flats sit inside the true circle, so holes come out a little undersized. On small holes for pins or screws that’s often the whole 0.1-0.2 mm you end up drilling out.
- 3MF is a decent middle ground when you’re sending a file to someone else: it’s still a mesh, but it carries units, so nobody opens your part at 1/25 scale.
- Whatever format you pick, a quick test plate with a few hole sizes (3, 5, 8 mm) tells you more about your printer’s hole compensation than any setting does.
On the “smart infill” point: Orca already has per-region modifiers you can place around holes to add perimeters there, which covers most of what I’d want until something automatic shows up.
CNC Kitchen’s STL vs STEP note matches what a lot of functional-print folks hit: STEP keeps real solids; STL is only triangles and often loses units. After export, open the file once and measure a known designed edge before slicing. A browser CAD viewer is enough for that check. CADProps opens STEP/STL/DWG among ~92 extensions; natives processed on CADProps servers. STEP File Viewer Online: Open STP Files, No Account | CADProps
