Copy existing sketch onto a new body?
So I created a fairly detailed sketch and now I would like to use it on a new body I created but can’t figure out how to do it. Is it possible?
Thanks all
You can project a sketch onto a body with the Project tool.
If the body is flat, you have the option of projecting as a sketch or an edge.
If the body is curved, you can only project an edge.
Hi Mike, as usual I went experimenting after posting this and found the project, it seemed to be what I needed, but when I tried it my sketch got warped out of dimension. I don’t know if it’s because the face of the body I’m trying to project onto is at a 20° angle or if I did something wrong?
If the body is at an angle the projection will be distorted. Either rotate the body parallel to the sketch or visa versa before doing the projection.
Thanks Mike, while you’re here is there an easy way of putting a body back to 0 Z-height on the workplane without trying to guess?
make a temp body with one face at your desired Z-height. Then use Align to that face and afterward delete temp body.
Hmm okay, thanks. I was hoping I was missing some sort of shortcut key but not to worry lol. Maybe one for the feature request thread :slight_smile:
