Since Sketch Planes are relative, it would help assure that they are where we think they are. Right now we have to actively select SP to determine if they are off.
I discovered we had some SP that were off by 0.01 meter. This was problematic because it meant that walls didn’t meet the ceilings and therefore would create a light leak in Unreal.
The end result is that we scrapped extrusions for a multistory building in order to assure that it was correct, rather than attempt to reposition all of the meshes.
It would be incredibly helpful to create measurement between SP. It would make my world if they remained active throughout the project. Then, if someone accidentally moves a SP, it becomes immediately obvious.
By doing this, we can see, at a glance, that SP are where we designed them to be, not off by some fraction of a meter. This assures us better quality control, and less rework.
Right now, I as it stands, I have to assure that the SP is correct by individually selecting each one. This doesn’t sound like much but we have 16 SP. I’m not mad at the rework, that’s normal in this business, but it puzzles me why we cannot measure distances between SP much less display the distance as a measurement.
Yes, it is slowing us down because we had to scrap extrusions that were an incorrect height.
