Forgive my lack of proper terminology. I would like to create a pattern to reduce work time on my leather craft by using a laser cutter to cut my pieces, stitch holes and all. Essentially spacing small diameter holes offest 3mm from the edge of my design spaced evenly apart. If my design was a perfect circle or line i could use the pattern function, but this does not work for complex curve paths, to my knowledge. Any help is appreciated.
Hi John,
Check out this post. Alex @Xdrakosha demonstrates a great way to do this.
Wow i never would have figured that out on my own, ill have to give it a try but that looks pretty much exactly like what im trying to do. Thank you so much
You’re most welcome. You can also use the patten tool when you have a “long” straight or perfect radius… mix and match.
hi there. I am trying to do a similar thing but this video isn’t loading. on a tight timeline too… can anyone help with this? thank you!
Thank you so much!
I really enjoy coming here and learning something almost every visit.
