Extrusion failed
Hello
I imported a simple image and then I outlined it; it’s all one piece (shows 33 sketches that are all connected). when I try to extrude it it says “extrusion failed.” couldn’t find anyone else having this problem by searching the error message. the design is simple enough and it has only
I’m having the same issue. Have yet to find a solution
Can you share the workspace, vid on the specific issue?
It’s says I cannot upload files because I’m a new user
If I highlight the selection and try to extrude the shape up, it says failed extrusion. It does the same if i use the extrusion option as well. Would it have something to do with the shape itself?
Same problem. I used draw tool to outline, but once the area is closed it won’t extrude.image
Hi - with splines sometimes extrusion is not easy - it is a know issue and we will try to fix it. What helps sometimes is extruding them in parts (separate the closed sketch with lines), then Union them - we will look into the issue in the future.
Try to keep your spline shapes as simple as possible … less is better with splines? :sunglasses:
Practice, practice and practice with the spline tool … I’m always doodling with the spline tool to improve my techniques … there’s some great YouTube tutorials to check out for the spline tool…image
