Filet / chamfer edge does not work after extruding a sketch (video attached)
You’ll need to select ALL the edges together before chamfering.
Either click to select each edge in turn until they’re all highlighted or…
…select top view then draw a bounding box over the front edges and tab to select edges only.
Now you will be able to chamfer them as desired.
Hope this helps :grinning:
