Great that we have fillets on sketches. I’m sure this is user error, but I can’t figure out how to keep the overall dimensions of a sketch while adjusting the fillet radius. i.e. make a rectangle, add fillet to all four corners using r variable. now retain the overall size of the rectangle while adjusting the fillet radius?
It’s not applying the fillet it’s changing it’s value after being applied. So in your case, make the rectangle and create the fillets, setting the fillet radius to the variable r. then change the variable value. The overall size of the rectangle changes.
Ah yes! I think this is because at the point of the radius change the rectangle is no longer constrained as such. It’s just straight lines and arcs. So increasing the arcs sizes will also push the lines out since their lengths didn’t change
I think with the current implementation of sketch fillets that’s unfortunately just how it works. The sketch doesn’t “remember” it’s a filleted rectangle after the first fillet creation.
yeah it does seem like a limitation I can’t seem to work around. For me, I generally know how big I want something to be and the fillet radius is an aesthetic choice I want to experiment with. not always, but probably more often than not.
(edit)
Ok, well it is possible by creating the fillets, deleting the segments and setting up tangents but that’s a little silly
Rectangles are special sketch objects that the constraint solver handles differently. When a fillet is applied, the rectangle is broken down into individual lines and arcs, and its original rectangle-specific behavior is lost.
Currently, the Fillet tool does not automatically add horizontal, vertical, or parallel constraints to preserve the rectangle’s geometry.
We are also considering a couple of alternative approaches:
Preserve the original corners using coincident constraints.
Add construction geometry along the diagonals to maintain control over the rectangle, even after applying fillets.
Which approach would you prefer? Any feedback on the expected behavior would be greatly appreciated and will help us make the right design decision.
If I’m understanding I think this is what you want. So adjusting fillet radius does not affect overall size. Sounds like maybe the second option does the same but I’m not sure. Really it’s exactly the same as current behavior on a 3d shape, just in 2d.
There is no one-size-fits-all solution, which is why I asked what you would expect in these cases. The goal is to learn from your perspective and understand what works best for different scenarios.
For a simple rectangle, adding parallel constraints between opposite edges is enough to preserve its shape. Persisting the corner points is another possible solution, but for many users, this might just add unnecessary noise.
For a center-point rectangle, however, preserving symmetry might be also important. This requires a different approach, e.g using diagonal construction edges.
Keeping the corner points was actually part of the original plan. However, due to some platform limitations, we discovered that points cannot exist independently and must belong to a geometry. We are planning to release a new point tool in the coming weeks, which will also open up new possibilities for sketch fillets.
An option might be to add the fillets to the rectangle while just leaving the original rectangle geometry as-is, not cutting the corners off it at all.
