Get in touch with Shapr3D Support faster
Hi @Kourosh,
I just answered the support ticket you opened, thanks for posting here also.
Having similar issues. Im using this cad app for 3d printing and cnc milling and cant seem to get consistent exports. Ill measure 3 times in the real world, draw and design replacement parts for my car, in shapr the dimensions and measurements are correct from my measuring notes, go to export and the dimensions will be off.
I thought it had to do with setting the unites of the project. So i started a new project, kept everything in mm. Export in mm and send to my 3d printing/CAM program and its still wonky.
Hello! What are the differences compared to the CAD model?
I had the same problem and they helped me out. The MM to inches thing is a glitch, surprised they didn’t fix it but it was probably a low priority given their additional major feature releases lately.
Anyways, they helped me out, use .3mf!
They recommended it, after that, zero problems with the dimensions. It’s supposedly the new standard over stl and step etc.
Let me know how it works out for you.
It seems you don’t except any of my email addresses.
I need to change from my iPad to the laptop some times as the iPad app will crash at anything over x amount of megabytes but when I do this it wants more money , wel if I’ve logged out on one then I should be able to log in on another on my account shouldn’t I ?
You should be able to use Shapr3D on up to three devices without having to log out. Can you please check if you run the latest, 5.531 version?
If it does not work after updating, please open a support ticket using the link below and let us know the following information:
  • The email address of your Shapr3D account is registered
  • The detailed hardware a software specs of the iPad and the laptop.
Help… I deleted the folder by mistake. There are many design files in it. How can I recover it?
Hi Shapr3d - is it possible to spheres a flat pattern - or bodies? I am looking to apply a raised pattern to rounded objects like a bowl or vase… I can of course project onto a curved surface but ideally need it to ‘wrap’
Thanks!
I can’t export files with MacOS. The most recent Shapr3D 5.681.0.7286 update. I submitted a couple of support requests but haven’t received a response.
Why can’t I contact you with a Gmail account? That is how I get emails from Shaper. I would think since I paid for the service I would be able to contact the company when I need help.
按照教程分步进行模拟的情况下:1.为什么在中心点创建第一个矩形后中心没有锁定图形的功能?直到第二个矩形画出来会显示锁定按钮呢?
2.每画出一个图形如何解放鼠标,画出图形后鼠标只要在画稿中松开也是上一个画出的图形,如何关闭?
以上出现的情况使用的是shapr3D windows版本。
hello is there any way someone from Shapr3d can work when i deleted my project ?
Our business hours are Mondays-Fridays, 8:00 AM - 4:30 PM, Central European Time.
Please kindly reply to the ticket with the necessary details.
this is SOOO frustrating! I can’t verified my school email address,I can’t never receive that email to validate my email address, however, I have verified my email address to get to this page!! Very convoluted! When I try the Shapr3Ds support link above it then asks me to validate my email, which for some reason I don’t ever receive! PLEASE help.
<Marcos
Furthermore, my account was setup incorrectly, it needs to be a school account and it’s not
When I subscribed to the software on my IPAD, but I can’t use it in my Windows
Could you please submit a ticket on the support portal? Please include your Apple Order ID.
Hello, I have a problem and the program doesn’t work. I’m a university student and I’ll forward the email to: miroslav.badura251538@seuniversity.eu Can you take a look at it for me? I don’t know where I’m making a mistake?
We located your support ticket and replied to your request.
