I have a question regarding a scissor handle im trying to make for my master thesis. Ive asked before on how to model the ringloops for the scissor and im now having trouble modeling the rest of the scissor to the ring. The Loops are not straight in any way and id like to have a smooth transition between the two parts.
This is what the “replace face” tool is for. Select the face you want to make contact with the other object, hit “replace face” and then select the finger loop you want it to conform to.
There are some limitations to this tool, but judging from your screenshot it should work fine in your scenario.
EDIT: LOL, of course @Xdrakosha beats me to it by seconds!
Your handle is thicker than the finger loop you want it to conform to at the bottom. When i just slightly scale down the edge that is too high, replace face works fine.
