I have a model I’ve created, but I need help figuring out how to make the section that goes between the two blue faces, and I need the angle to be smooth.
Use loft with tangency or with guide rails. Or sweep.
when i try to do that, i says that the body wouldn`t be valid
What exactly?
If you can share the model I will show you how to deal with it.
I can show you an example, but that doesn’t mean it will work in your case.
tell me if that works for you
now it should work
how did you make that look so easy, make me feel a little stupid
Practice.
Sorry ![]()
need to learn the program a little more
thank you sooooo much
I don’t have access to the file, so I can’t try. But i wonder why you created a new arc (spline)??? There seem to one already… Does it fail using that one???
Existing one was in incorrect place. Just didn’t want to correct anything and show how it should be done from the beginning.
Just so I understand this too: Does it matter if it’s in the middle, outside or even inside?? I would think it does not, as long as the ends is perpendicular to the face. Or am I missing something??
It doesn’t really matter. It was just more convenient for me that way, and I didn’t want to modify the original sketch.
