Hi everyone,
I’m working on a layout and would really appreciate some help. Please refer to the attached image as an example.
I’d like to align the centers of all the circles so they are perfectly in line.
The internal spacing between sketches (as marked by the blue dot lines) needs to be exactly 5 mm.
The rectangle is 49 mm × 71 mm
Each circle has a diameter of 17 mm
The current layout was done manually, and I couldn’t locate the alignment tool or figure out the best way to achieve this accurately.
Could anyone kindly advise how to do this properly?
Thanks in advance!
